01 c320 not starting
Car is an 01 C320 with 120k on it.
About 2-3 weeks ago the engine just cut off when I was driving. After a few attempts to start the car, it finally started but it would only go into limp mode. After a few more tries, the car was back to normal. Searched around and determine that my plugs, wire and fuel filter needed to be replaced, they were due any ways. Replaced the plugs and wires with oem 1st and the car started up but was really rough then the engine died. So i replaced the filter but that did not fix anything. Next I replaced the fuel pump, that didn't help, then the fuel leveling unit, then the fuel pump relay. Everything that i have done doesn't help at all. I rented the fuel pressure gauge from autozone I have no fuel pressure at the valve. Is there something that i am missing.
C-house
I tried your suggestion about pulling the maf sensor and starting the car but that didnt work.
Not sure what else can be causing the problem on whys there is no fuel pressure.
