Brake sensor!
Old Jul 29, 2017 | 04:10 PM
Ronnieg63's Avatar
2006 E350
Brake sensor!
Bought a used E350 that had the brake repair shop warning on the dash. I already knew what it needed or so I thought. Took driver side wheel off and sensor missing altogether. Can't figure out where it would plug in if I bought one because all the corresponding wires are gone! Help!,
Old Jul 30, 2017 | 04:22 AM
alecmascot's Avatar
W204 C220CDI 2011
There is probably not a wear sensor on every corner on that model.
Old Jul 30, 2017 | 03:23 PM
RWDlifer's Avatar
2005 C230K SS
Check the passenger side, it's usually on that side...at least on the C
Old Jul 30, 2017 | 03:25 PM
efzauner's Avatar
2005 C240 2011 R350
yeah its not on all wheels. I find it a bit of a pain. They go off way to early and then you have the constant warning light. SO i have a pigtail from a used sensor that I shorted together to basically deactivate the system. If you rotate tires even every 10K you should be able to monitor pad thickness and schedule brake work.
