Help!
Over the night and this morning, I have read several popular threads on this site and watch a couple of videos on YouTube and this is where I am...
I have not been able to get the engine started. I support the importance of good MB OE or OEM parts, but I am not sure that MB OE CPS failures were any less for this generation MB engines that place it in such a hot forsaken location. "2" CPS failures in 2.5 years and little more than 12K. miles ? The first back in Nov. 2014 @ 96K. and Just this past June 2014 @ 106K. miles, I also did the valve covers gaskets/air breathers, spark plugs/cables, clean the MAF sensor, engine & cabin filters, clean the entire assembly, replace pulleys/belt, oil/filter, flush P/S and a few other preventative things and since I had easy access that engine was clean before I started and after I finished and most wires check & connections were clean with electric cleaner and lube with dielectric grease. A few people never had any problems with it, could there be another roots cause for its failure?
Ok, Today, re-check battery voltage 12.5v., I just check the fuel pressure, 20 PSI with the switch off and 59 PSI with ignition on, 61 PSI or higher at high RPM, then pressurize with power OFF it stayed at 51 PSI, I guess that is OK?
Then I look at the MAF sensor it looked clean but once again I clean the MAF sensor with MAF cleaner. The Car did not start, and the check engine light has not come back on since I cleared code P335 last night.
Next, I removed the CPS, it had a little oil or dielectric grease, not much but some, put a voltage meter to the two prongs and exited it moving a metal piece close to the magnet it read 0.5mv - 164mv or higher if I moved it quickly. so according to a few videos that mean is working. Now what to do next? I need some input or suggestions, You are welcome to chime in
CODE p0335=
faulty CPS
CPS harness is open or shorted
CPS poor electric circuit connection
the signal plate may be damaged
the starter may be faulty
starter system circuit
dead or weak battery
I guess I'll be testing for a parasitic drain next. My car is a 2005 but read about issues with the seat modules mostly in 2001-2004, maybe I just ran out of borrowed time. I disconnected the negative wire and hope to be able to charge the battery to 100% overnight
Any advice is welcome, Thanks!
PS: I stop by AutoZone to get some service supplies for upcoming maintenance on my Mothers car, and the Manager ask me about my car saga and after I told him, He asked if I still had the Duralast CPS or the receipt? Wich I did have in my car, "he just gave me my money back" I had not even implied he should, That was very decent of him!
