c240 stuck in park, no crank
Old Aug 4, 2017 | 06:38 AM
Dee2017's Avatar
c240
Hi I have a c240, it is stuck in park then after a few hours it can start working properly again. The abs light comes up and then it sticks in park once you turn the engine off then it will not crank again. battery is fine. I plugged obds reader into it and pulled up 9 faults, deleted them then it started again drove it into my drive and then abs light come up again and once i parked it and put into park it got stuck again. I changed the brake sensor thinking it could be that but it hasn't changed it. any ideas what else it could be? once its going it works perfectly there are no other symptoms.
