ABS/ESP Fault C1114 Right front speed sensor SOLVED!
The ABS lamp light up in the dashboard, so I used a fault code reader to see what the fault was and its says : C1114 L6/2 (Right front speed sensor)
Fine no problem I went out and got a new abs sensor, change it and cleared the OBD code.
I went for a drive and the abs light came on again
I read the OBD fault code again and the same code showed up: C1114 L6/2 (Right front speed sensor).The it must be the ABS ring.
I found out that it don’t look like a normal ABS ring, but more like a Shaft Seal.
Mercedes Part number : A 203 330 00 60
Hers sum pictures how it look like and were it is.
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
So you unbolted the hub, replaced the seal...and that's it?
I just bought the iCarsoft Mercedes and it's telling me I had a fault in the right rear sensor, though no
ESP or anything on the dash, so I'm expecting I may do this soon.
We found the disk guard to be very badly corroded and the guard part which covers the ABS sensor where it protrudes through the housing
fell away in my hand. It is possible that this in fact was the cause of the trouble. £12 for the ABS ring/seal and £25 for a new disc guard from
a Merc dealer has the lights out and the ABS is working well again. The job looks good too! Shall be doing the port side when the rain stops?
