Brake calipers
Old Aug 22, 2017 | 03:01 PM
Wabayle's Avatar
2006 c230
Brake calipers
2006 c230 front brake calipers vibrate when stopping.
Replaced brakes and rotors.
What else could it be?
Old Aug 22, 2017 | 04:46 PM
cruzer076's Avatar
2005 Black C230
I have a 2005 C230, that its vibrates when stopping as well..I was about to change the rotors or get them turned...
Did you do replace all 4 brakes and rotors or just the front?
Does the problem only happen when applying brakes?
I'm curious to see if it's something else too...
Inquiring minds want to know.
Old Aug 23, 2017 | 05:24 PM
cruzer076's Avatar
2005 Black C230
Have you checked:
Wheel Bearings?
Control Arms?
Tire Rods?
Sway Bar Bushings?
A quick way to check those is to jack the car up in the front and try to move the wheel from side to side to see if there is any play....then try to move it back and forth...up and down.(holding the top of the tire and bottom of the tire and pushing and pulling)..if there is any play or wiggling, it most likely will be suspension issues...with the sway bar you just have to grab it and try to move it to see if the links are loose..do this on both sides.
I just got my C230 2 days ago, so I haven't had a chance to dive in and trouble shoot yet... but if you already replaced what I would think would be the obvious culprit(brakes and rotors) then most likely it may be suspension related or more rarely tire related...
Let us know what you find out.
PS>>>CAN I HAVE YOUR OLD ROTORS AND BRAKES
Old Aug 28, 2017 | 01:43 PM
Wabayle's Avatar
2006 c230
Yes, I've replaced Bearings control arms, all four brakes, calipers & rotors.
Old Aug 31, 2017 | 05:51 PM
cruzer076's Avatar
2005 Black C230
Have you tried rotating the tires? Are you'rs directional? I was going to say just rotate the two front tires so they are going the other way...
Other things to check is your master cylinder or your ABS is acting up...
Any check engine lights?
