Rims Fitment Question
I have a 2003 CLK 430 which has passed on the the great Autobahn in the sky
I was wondering if the rims would be a good fit for my 2002 C240?
Thanks in advance for you help.
Nekko
Can I teach you how to answer the question yourself?
1: find out what wheels are on your model! Look in the owners manual. read the size on the inside of the wheel Diameter, width, offset.
2: Find out what wheels are on the CLK...
Manuals can be found online. by googling "mercedes benz owners manuals" There is a MB USA site !
Then you can use various online tire sites to
1: compare one wheel/tire combination to another wheel/tire combination. in terms of overall diameter. They should be within a couple percent so your speedometer and odometer are still acurate.
http://www.1010tires.com/Tools/Tire-Size-Calculator3
2: the same sites will give you offset calculators
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
The offset will determine if the tire will rub on the inside, perhaps against a suspension part or the shock strut, or on the outside on the fender...
let me know what you come up with and happy to help out.
NP
I will check the bolts. It's not 4 -matic or staggered.
Thanks again
