2003 Mercedes-Benz C230 1.8 Komp. Turns On & Off
Old Sep 13, 2017 | 12:37 PM
Patel151's Avatar
2014 GL350
I have a 2003 Mercedes-Benz C230 1.8L Kompressor but the car has been having starting issues recently. One day I was turning the key in the ignition and there was a slight delay in the starting and it was slowly starting then started up. After running it for half an hour, I turned it off and tried turning back on, but it wasn't starting or making any cranking noise. The battery is good and not sure what else could be the issue. Sometimes the car turns on and sometimes it doesn't turn on.
Today I tried starting the car and no luck, but all the lights and radio and everything works, plus there is no loss in power from the headlights when trying to turn the engine...
Old Sep 13, 2017 | 03:34 PM
dboyrusky's Avatar
2019 GLC300 4matic, 2019 C300 4matic, 2018 C300 4matic, 2009 C300 Flex, 2004 C230 Kompressor
Read codes, Check fuel delivery, pressure, fuel pump
Old Sep 20, 2017 | 09:54 PM
Patel151's Avatar
2014 GL350
But I don't understand. Today the car was running for an hour. I let it sit while I warmed up and drove it around the street 5-6 times then parked it. I turned the car off. 10 minutes later I try to start the car, it cranks for 2 seconds and suddenly just stops cranking.
