W203 Bi-xenon headlights problem
Old Sep 14, 2017 | 03:15 AM
Karce12's Avatar
Mercedes-Benz C220 W203
Hello, everyone. I've got W203 C270 CDI, 2001y Mercedes Benz. I cannot pass technical inspection, because there some issues with my Bi-xenon headlights. I've bought new D2S bulbs, but not very expensive ones, at the technical inspection shows that there is almost no lights, they are dead... How can i solve this problem? On both headlights is the same problem... The main problem is Low beam light, high beam is alright.. I have noticed that headlights looks foggy, I am planning to polish them. It would help a bit or not?
I am attaching my headlights pic. Thank you for your time!
Old Sep 14, 2017 | 01:58 PM
RWDlifer's Avatar
2005 C230K SS
Your headlights look fine. If you have low light output it may be the cheap bulbs or the igniter/ballast
Old Sep 20, 2017 | 03:05 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
check the ground wire for the lights as that will cause an issue as well. Since it is both lights it will more than likely be something that is common rather than ignitor and ballasts since each light has it's own.
Old Sep 20, 2017 | 12:28 PM
WaveyKat's Avatar
Something Slow
post a picture with the lights on!
