Motor mount bolt part# HELP!
Got all ready to do my motor mounts, dropped the splash shield for the engine and the head of the driver's mount bottom bolt fell to the ground. 😠
So I stopped, put the shield back in place and put all my tools away. Anyway I'd like the part number so I can call the dealership and see if they
stock the bolt before I waste a trip.
It's the 13MM bottom bolt, I'm going to get both side just to be safe so if there's a different part# for the passenger side I'd appreciate that also.
NP
Also guessing that I should get new top bolts [16MM one].
NP
Bottom bolt is: A 202 990 22 01
Top bolt is: N304017 010051
Top requires a crush washer which they didn't have, should be able to get it at a hardware store, use bolt to get correct size.
