Coupe rear door speaker grille
I have found how to remove the coupe door panel in previous threads, but I was wondering before I proceed if any of you know if it is necessary to remove the whole panel to replace the rear speaker grille. Mine got crushed over the weekend and it is killing me to look at, and it needs replacing. I am hoping that this will be easy. Any help will be appreciated.
1 Post
2002 C230 Coupe
You have to remove the whole door panel in order to replace the speaker grill. The grill is melted onto the inside of the panel so you either need to cut or grind off the melted posts.
Screw will do when you put the new grill on. But just be carefull as the shop broke mine and I needed to JB Weld a crew thread onto the original hole and then fasten it with nuts...
