Seat heater not working after upholstery repair
Wires wrapped in electrical tape
Cut wires
I soldered the wires and used shrink tubes to protect the soldered portion of the wire. Unfortunately, that did not fix the problem. I also checked the fuses(#25 and #41) based on the assumption that the poorly-repaired wires had shorted, but the fuses were fine. The controls for the seat motors work fine and the passenger seat heater also works.
Here are my questions:
1. Does anyone have any suggestions for how to access other wires that may have been damaged in the repair process? I'm wondering whether I can remove the trim on the side of the seat to see what is going on.
2. Are there any other components (such as a relay) that could have been damaged by a short?
3. Could the upholsterer have damaged the seat heater grids when stitching the new panel to the cover?
I can always remove the seat and take it back to the upholsterer and tell him to fix it, but I don't have any faith in the guy right now and if I can fix it myself I will avoid wasting a lot of time.
Also, while I am annoyed with the upholsterer, I find it more productive to treat people as intelligent individuals and provide specific guidance on how I want them to correct a mistake. For example I would prefer to say, "Wires a and b between the seat back and the seat bottom need to be soldered together," than "You are an idiot, fix this."
If you have access to an electrical meter (VOM, as in volt, ohm, multimeter) you may want to see if there is a complete open (infinite ohms). when checking the wires to the seat. I would expect there to be some level of resistance, but not complete open. However, can't say for certain that is the case, but would be a clue. If you get some type of resistance reading, then there are next steps. If it is a totally open circuit, then your option is to go back to the upholsterer and work a deal for them to fix this,.
Another test with the VOM, would be to measure the voltage present at the connector to the seat when the heater switch is on. I think you should see between 12 and 14 volts (again just speaking from general experience). If you don't see anything (as in less than 1 volt), it could it be the connector got damaged.
Getting the wires soldered together and wrapped with electrical tape is also a must if it looks like the connector is okay (you have power when the switch is on) and there is a level of resistance reading for the seat.
Most of all good luck! Heated seats are practically a mandated option here in Minnesota.
Regards,
Bruce
I have a multimeter and I was planning to check for continuity this weekend when I have some time. I hadn't thought of checking the voltage, but I will add it to my list.
It is not a cold in Virginia as it is in Minnesota, but I've become accustomed to seat heaters in my other cars and I will need to keep after this until I come up with a fix. I think a trip back to the upholsterer is likely, but I'd like to provide specific guidance to him on the repair.
https://www.ebay.com/itm/Mercedes-Be...1VzgjI&vxp=mtr
Thanks for the suggestion. I'm still in the brainstorming phase on this problem and I'm considering all possible causes. I took the seat out of the car and brought to the upholstery shop, so I don't think that is the cause. Maybe when I was doing my repair something happened. However, I'm pretty sure I had disconnected the seat wiring in order to tilt the seat back for access to the cut wires.
I'm going to have some time tonight or tomorrow and I plan to follow bjbina's suggestion and check for continuity.
I think there is a poor connection somewhere.
So, I'll be bringing the seat back as soon as I can.
