Xenon headlight problem anyone else??
Old Apr 13, 2002 | 04:02 AM
yshaw's Avatar
C320
Hi to the all knowlegeable people in this forum.
I own a 2001 C320 with the factory xenon headlights. Recently I have been noticing that my light pattern at night seems to have changed. The light pattern is now limited to only about 15ft in front of the car. Both xenon lamps are working and light up fine. But they almost seem like they are pointing way down such that they focus too near to the car. I know that all factory xenon light have some kind of "auto leveler" sensor that points the lights at a certain angle wrt to the (road?). My guess is that this angle sensor on my car is not working and it tilts the beam's angle more down than it should be. So visibility at night is greated limited now. Road markers beyond 20 ft don't even light up now. And I remember very clearly when I first got the car that the lights light up a same stretch of road a lot better than it does now.
Does anyone else have experienced the same problem? Any advise would be appreciated.
Cheers
Old Apr 13, 2002 | 05:59 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i haven't pick up my C32 yet but i use to have a 2000 BMW 328CI it has the auto leveling xenon too...you can tell its leveling by just switching the light on, you will see the focus point move up and down usually i can hear mine working...its different car but hope that helps...anyway
i think it would be best and the most easy way just to bring the car back to the dealer to check.
Old Apr 13, 2002 | 09:55 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
That's easy enough to check. When you first turn your lights on at night, pull up to a garage door or a wall and then turn the lights on. You should see the beams flash on, and then move down, then back up.
