Can anyone identify this component?
2001 C240 Elegance Auto Lthr
Hi,
I have a 2001 C240 Automatic and I was looking under the hood today and found a component that was making a fairly loud ticking sound. Can anyone tell me what it is? Can anyone also tell me if its meant to make a ticking sound and if not then what this may indicate (apart from the fact that it's probably knackered!!)?
enc: 2 pics below
Thanks.
Paul
This is it:
and this is where it is in the engine bay:
enc: 2 pics below
Thanks.
Paul
This is it:
![](http://www.stlhosting.com/upload/c240module.jpg)
![](http://www.stlhosting.com/upload/c240enginebay.jpg)
1 Post
1997 Toyota Tacoma 4x4
That is the charcoal canister purge valve. When it ticks, it is working. Fuel vapors in the tank build up, are stored in the charcoal canister, and are released into the engine to be burned. The purge valve is what delivers the vapors into the engine from the canister. There is an updated mounting bracket for the purge valve that is supposed to make it quieter, but you will still hear it. It will always make noise, you'll probably have to learn to live with it.
1 Post
Originally posted by truelove
at what frequency does it tick? i can hearing ticking under my hood too, but i assumed it was the spark plugs.
Ticking Spark Plugs?
Thanks MBTech208. I wasn't sure so thought it best to check. Never heard it until I opened the hood to poke around.
The noise is not too bad kind of like the level of volume a loud quartz clock makes but faster (say 4 ticks per second). I thought it might be a component on the way out which is why I wanted clarification.
In fact it is kind of like the sound a spark plug makes when shorted out against the engine body (tick,tick,tick,tick) so i can understand truelove's comments.
Thanks.
Paul
Thanks.
Paul
1 Post
2003 MB C230 coupe
Re: Ticking Spark Plugs?
1 Post
Originally posted by sunman
I hear i t tick as well. I thought it was a problem with my car only. I have a 2003. Would it have the updated mounting or shall I request it?
