Rear Windshield Wiper Fluid Leaking Inside Liftgate
2003 C240 Wagon calls for fluid, but none comes out. Instead, after the motor buzzes, you will notice fluid leaking out from inside the liftgate. Is this fixed by replacing the motor and grommet, much like leaks that happen in the front?
2003 c240 4matic wagon
remove the liftgate trim on the inside several push clips along the edges and maybe 1 screw in the middle also has several clips you have to pull pretty hard (been awhile) mine the pipe running through the wiper motor was broken and I need new motor as you can buy the pipe you may just have a disconnected/broken line
