2003 C240 broken pulley
It is amazing that the belt has stayed on, and I have no idea how long this condition has existed. Does anyone have a DIY on this repair? Sincere thanks in advance!
You'll need an inverted torx to put on the front of the tensioner to move it to ease the tension to remove the
belt, and not sure what's holding the idler pulley. Can't see if thats the bolt on the front, or a plastic cover.
Torx? Everything on these cars is torx, Inverted torx or metric Allen,
well and good old metric bolts too.
Hopefully this information saves someone some time on this repair.
The coupe had a strut connected to the tensioner. The strut did not show up for our VIN at the dealer, which was strange. The parts guy checked several times to make sure he had the manual transmission V6 C320. I had him confirm that the version with a strut, uses the same tensioner part. It took longer to transplant the strut than it did to replace the tensioner. You have to remove the top bolt of the strut and then remove the bottom bolt of the strut after you remove the tensioner. The strut is attached to the tensioner with a self-tapping bolt. It took a bit of muscle to get it screwed into the new tensioner, and some finagling to get the top bolt realigned with it's mounting hole.
Remnants of tensioner pulley wheel
Strut connected to tensioner
