oil in coolant
Old Feb 3, 2018 | 10:04 AM
bytal's Avatar
06 c230
oil in coolant
So we recently found oil in the coolant reservoir of our 06 C230. I'm trying to figure out whether its engine oil or ATF and how it got there. I dumped the engine oil and asides from being dirty, it looked like engine oil, I pulled one of the transmission lines off the cooler to check the transmission fluid for contamination. No milkshake there either. I've tried revving the engine up good to check for white smoke to see if there is a head gasket leak and that has come up negative too. I know there could still potentially be a leak between an oil galley and a coolant galley in the head. Are the oil coolers on these cars cooled with coolant? I didn't see any lines running to the cooler, but I'm wondering if the coolant is run directly through the oil filter housing. I know radiator is quite possible too, and heard that there were problems with the Valeos, but I believe that was earlier that 2006. TIA
Old Feb 5, 2018 | 10:57 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Replace engine oil filter housing/cooler assembly. It is one of the most common problems for M272/M273 engines.
Old Feb 6, 2018 | 08:13 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Are you loosing any fluid. how bad is coolant reservoir?
Old Feb 6, 2018 | 09:38 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Send the fluid to Blackstone labs for analysis.
Old Feb 16, 2018 | 03:52 PM
Peehussle's Avatar
06 e350
Oil cooler
Oil cooler gasket needs to be replaced
