Are AGM Batteries A Better Bang For $$ Than Flooded Acid Batteries?
Has anyone used these Evermaxx in their MB C class? What's your educated opinion or experience on expected life AKA durability?
Conversely, I found an ACDelco AGM at $199 on AMZN. Are AGM batteries that much better than conventional flooded acid batteries?
your prices seem good.. whats the diff? couple cases of beer?
I am a new MB C240 owner. How are you able to tell that your rear suspension links need replacing? Does it clunk when you go over bumps or just noisy like bushings are worn out, dusty or rubbing against rusted, dusty metals?
You can try something: losen one side lower shock bolt, then drive around, you hear what the clunking sounds like! it is quite loud!
