Reset Service Indicator - W204 Series
Old Feb 28, 2018 | 10:02 AM
Hughie's Avatar
2001 Mercedes C280, W204 Series
I have a 2007 Mercedes C280, W204 model. When trying to clear the B service overdue notification and used the instructions in the manual it comes back with a message service incomplete. The message also now reads service overdue 999 days and below has +15000 kms
Old Mar 1, 2018 | 10:22 PM
shan's Avatar
W203 (2007), W120 (1962)
See if this helps.
MB Reset Service Indicator Guide 2
Contents
Models 203 and 209 (C-Class and CLK-Class)............................................ .........3
Models 204 andX204 (C-Class and GLK-Class)............................................ .......4
Model 211 Up to 8/31/2003 (E-Class)............................................ .........................5
Model 211 as of 09/01/2003 (E-Class)............................................ ........................6
Model 219 (CLS-Class)............................................ ...............................................7
Models 221 and 216 (S-Class and CL-Class)............................................ ............8
Model 171 (SLK-Class)............................................ ...............................................9
Model 230 up to MY2007 (SL-Class)............................................ ........................10
Model 230 (SL-Class from MY2008 to Present).......................................... ........11
Models 164, X164 and 251 (M-Class, GL-Class, and R-Class)..........................12
1. Insert key into ignition, switch to position “1“.
2. Press buttons or repeatedly until the mileage is displayed within the Multifunction display.
3. Press cluster illumination button (1) 3 times in short succession. The battery voltage will be displayed and an audible signal will sound.
4. Turn key in ignition to position “2”
5. Press the up / buttons until the service menu appears.
6. Press cluster illumination button (1) once. The Oil Type menu is displayed.
7. Use the and buttons to select the oil used for the service.
8. Press the up / buttons to confirm. The display will show: “Reset Oil Confirmation. Push R-Button for 3 seconds”.
9. Press and hold the cluster illumination button (1) for 3 seconds. The message “Service confirmed” is displayed.
MB Reset Service Indicator Guide 3
1. Insert key into ignition, switch to position “1“. The mileage counter has to be displayed.
2. Press repeatedly until the TRIP option is highlighted.
3. Press and hold and within 1 second press and hold both for 5 seconds. The shop menu is displayed.
4. Press repeatedly until “Assyst Plus” is highlighted and confirm with . Options “Service Data” and “Full Service” are displayed.
5. Press until “Full Service” is highlighted. Confirm with .
6. Press until “Conf. Full Serv.” is highlighted, confirm with . The display shows “Service carried out?.”
7. Press to select “Yes”. Confirm with . “Cannot be undone” displays.
8. Press until “Confirm” is highlighted. Confirm by pressing . The display reads “Full Service carried out”.
9. Confirm by pressing .
MB Reset Service Indicator Guide 4
1. Turn key in ignition swith to position “2.”
2. Use buttons / until the “Service” menu is shown in the Multifunction Display.
3. Press and hold Reset Button R (1) until the Service Menu is displayed.
4. Use buttons and to highlight option “Confirm”
5. Press buttons or to confirm.
MB Reset Service Indicator Guide 5
MB Reset Service Indicator Guide 6
4. Press the up / buttons until the service menu appears.
5. Use the and buttons to select menu option „Confirm“.
6. Press until “Complete Service” is selected.
7. Confirm “Complete Service” with button . The display will show “Service Confirmed”.
2. Press buttons or repeatedly until the mileage displays within the Multifunction display.
3. Press reset button (1) 3 times in short succession. The battery voltage will be displayed
6. Press button until “Complete Service” is selected.
7. Confirm “Complete Service” with button . The display will show “Service Confirmed”. MB Reset Service Indicator Guide 7
2. Press and hold and within 1 second press and hold both for 5 seconds. The shop menu is displayed.
3. Press repeatedly until “Assyst Plus” is highlighted and confirm with .
4. Press until “Service carried out” is highlighted. Confirm with .
5. Press to select “Service due”. Confirm with .
6. Press to select “Full Service”. Confirm with .
MB Reset Service Indicator Guide 8
5. Use the and buttons to select menu option “Confirm“.
7. Confirm “Complete Service” with . The display will show “Service Confirmed”. MB Reset Service Indicator Guide 9
1. Insert key into ignition and switch to position “1”
2. Press button or until the main mileage display is shown.
3. Press reset button R (1) and hold for 3 seconds.
4. The message "DO YOU WANT TO RESET THE SERVICE INTERVAL? “CONFIRM WITH R BUTTON” displays.
5. Press button R (1) again.
6. Switch off ignition and remove the key.
MB Reset Service Indicator Guide 10
1. Switch ignition to position “2”
3. Press button oir until the service menu appears in the left display.
4. Press button R (1) for approximately 5 seconds. The message "Service interval... Reset: Press reset button for 3 seconds" appears.
5. Press and hold button R (1) for approximately 3 seconds to confirm.
6. Switch off ignition and remove key.
MB Reset Service Indicator Guide 11
Feedback welcome on startekinfo.team@mbusa.com.
MB Reset Service Indicator Guide 12
Old Mar 2, 2018 | 01:13 AM
Hughie's Avatar
Thank you Shah when I serviced car the engine light was on. We disconnect the battery which it appears now needs replacing. On reconnecting finishing service we used the service due notice you supplied however it will not confirm service and gives message service not completed. This is the predicament I am in .
Old Mar 2, 2018 | 10:58 AM
shan's Avatar
It worked for my son's W204 MY 2011 after I changed the oil and the filter.
Did the screen ask you to choose the oil grade 299.3 or 299.5?
After choosing the oil grade, it should reset.
I don't know why it does not work for you.
Old Mar 2, 2018 | 11:01 AM
shan's Avatar
If your car is MY2001, it cannot be W204.
I would assume that it is pre-facelift W203, no?
