SRS light -- tools?
Old Mar 21, 2018 | 01:47 AM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
SRS light -- tools?
Hi all,
My mother has a 2003 C320 which she absolutely loves. Recently, the SRS light came on and she took it to a dealership I've had bad luck with. They said they'd "have to replace some parts before" they knew what was wrong. Is there an aftermarket tool for scanning the SRS status and getting a better idea of what the car is upset about?
Old Mar 21, 2018 | 02:21 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Yes, the commercial grade Snap-on code reader (there are other ones out there) that most indies have should be able to read the code in addition to clearing it. The typical $20 eBay ones will not work for SRS codes as it uses a different protocol. Hopefully there's an indie in your area that can read and clear the code for free or nominal cost.
If the SRS is indeed caused by a hardware fault (can be an airbag, seat belt clip, or seat sensor among other things), the faulty part would need to be replaced.
Old Mar 21, 2018 | 10:07 AM
tjts1's Avatar
C320
Originally Posted by BeachBunny
Hi all,
What the dealer told you about having to replace some parts before diagnosing it is complete bull ****. Yes there is an aftermarket scanner you can use at home for SRS and other codes on this car. It's called icarsoft i980 it's all over amazon, eBay etc. I tried to include a link but this stupid forum redirects to ****ing Walmart for some reason.
