ATF DIY - Do you guys use LubeGard Flush or similar prods?
Old May 1, 2018 | 01:22 AM
Jay11's Avatar
2003 Benz C240
2003 C240 87k miles
The car has been mostly parked as I attended to familial vicissitudes of life. On the check list is atf change, DIY. I assume the worst-it's never been changed. I came across LubeGard Flush, do you guys use this prod or similar? It says to drain TC and trans case after 15 minutes idle. Well for this year models they don't have a TC drain plug. So won't a lot of this Lubegard stuff be left in there for a while and from the language on the box it seems you better make sure ATF gets drained every where! If not lubegard do you guys use anything similar if at all?
Old May 1, 2018 | 09:33 PM
contact148's Avatar
2003 c240 4matic wagon
NO don't use anything except the Mercedes spec fluid
