cool air A/C new compressor problem
after changing new compressor (denso) at workshop i having problem .
1- A/C is freezing and working great for 10 min and when stop cool at all, after turn it on/off 5-10 time while driving its start cool again.
2- while cooling i have a very bad (gas, Freon) smell that i didn't have before.
i found the mechanic don't know much on my car (destroyed the first compressor) so i prefer yours help please.
B.R
Avi.
OK today at morning again A/C work great to 10min no smell at all and again stop.
but after few minute my car went to "limp" mode and my turbo is stop working.
i reset by OBD 2 (code P0299) Turbo wake up again but still no AC.
some connection between problem?
thank you .
When the compressor was replaced, did they also flush the AC lines and replace the condenser? When this type of compression fails it's prone to something called "black death". Basically the compressor dumps a bunch of metal shavings into to the AC system as it fails internally and turns the oil black. When you replace the compressor it's very important to clean out all the AC line and make sure none of that metallic garbage is left inside the system. If it is the old metal particles will murder your new compressor. A symptom of a dying compression is intermittent AC. Check your bill or ask the AC shop if they flushed the lines and replaced the condenser (condenser can't be flushed, only replaced). The installation manual for the new Denso compressor will tell you the same thing.
B.R
Avi.
Btw, that's not right. The Humidity reading is likely wrong. And, humidity readings in general are "questionable" in accuracy - even with the best instruments.
For those of us used to Imperial units 40C is 104F. :-O
Iirc, the highest dewpoint recorded (with official instruments) was ~~95F.
MaroBenz i am having the same issue. Purchased a 2012 C 300 used with 65K. I have experienced similar issues with my car. I have discovered that when the air "stops" working I can spray the radiator with a water hose and the fan goes back to normal operation and the A/C will work again. Seems like a sensor issue but I don't know. The problem only happens when i let the car sit in the heat all day (not running on 90+ days) and then try to start it. I'm assuming the pressure is building somewhere and cooling things with the hose will allow normal operation. Once it's running, it continues normal operation unless i shut down the engine and let the car build heat. After an hour of sitting I will have the same problem.
