rear sam issue, don't know if i need to change fuses or i need to replace the sam
hi all,
i attach a picture i obtained with SD scan tool.
hope someone can help me
cheers
rear sam issue, errors: rear brake light, the left arrow (which is accelerated) and the left reverse light
cheers
Hmm, looks like they are not "active", just saved in memory.
"short circuit or interruption on component ... "
Do you still experience the issues?
The roller blind not initialized error at the bottom is active though.
Yes i have still the issues. Even if i cancel it it returns later.
as regards the roller the problem is not so important because i have excluded the roof motor through a cable disconnection. Because it sas broken .
i have bought a rear sam with 0035455101 code and hope i will solve the lights issue replacing the sam hoping no need to recode it.
i will not mount it myself i hope is not too expensive through a technician but i will afford the expense if i can solve it, no problem =)
