Front strut mount gap on top
Hi,
C230 2007 manual 6 speed with sport brakes (AMG caliper)
I just replaced my struts with bilstein B4 -and mounts, also replaced the rubber top gasket. Kept the original springs. And now there is a gap between the top flange and that top gasket. Is this normal? see picture
The gap is on both sides same distance - approx 2 mm. The metal bracket and the top of the mount sits flush and is mounted as it should with the notches correctly positioned.
Thank you, I did tried to find previous posts about suspension and no one mentioned this, so I am thinking something is not right...
Octavian
Octavian
I have gap, I'm sure it not normal
After installing PSS9 suspension I realize I have a gap on the top strut and the plate, I'm sure it's not normal as going over bumpy roads it feels loose and clonks.
can someone let me know if its suppose to have a gap or not.
thanks.
thanks.
