2002 C230 P0500 P0600 lots of errors...
2002 C230 Manual
I have been researching this for the last couple of weeks.
I have an 02 C230, I have ABS, BAS, ESP lights, and the speedometer doesn't work. I'm getting error codes P0500, P0600. I bought the icarsoft i980, but I cant connect to abs, to find out which speed sensor is bad, and I am getting all kinds of CAN BUS errors.
The OBD read says the car is going 15MPH.
I did a resistance check on all the speed sensors and found one to me in the 800's while all the others were in the 600's, so I ordered a new speed sensor.
I disconnected all speed sensors but the OBD reader says the car speed is 15mph. Which leads me to think the transmission speed sensor, while searching for that I found the Conductor plate, but I have a manual transmission.
s there a conductor plate for a manual transmission?
Can anyone give me some ideas on where to start?
2002 C230 Manual
I took it to the mercedes dealership, they said they cant communicate to the abs module power and ground are good, I sent the module to BBA-REMAN, and I just got it back and I am still not able to communicate with the module, I will send it back tomorrow, does anyone know if or where the transmission speed sensor is?
No, not on manual... hmmmm....
whats the pn on the ABS module?
2002 C230 Manual
P/N A209 545 02 32
I changed the left front speed sensor and moved it to the right, same result, and I am getting ready to change the back left speed sensor to see if that makes a difference.
