2003 C230 fuel pump going bad? 7.56 amp draw
2003 C230 sedan 105k miles
Fuel filter was changed at 100k miles 4 months ago.
I heard loud noise from under the back seat for two times this week. It's louder than normal so I noticed it by putting my ear onto the back seat.
The draw is 7.56 amp. Is that normal?
The noise isn't there today. But I want to know if the fuel pump is dying? I would like to change it before I loose power on the freeway speed.
Hmm..well 7.5 x 12-13v is 90- 97 watts.
But it has to move a lot of fuel and at high pressure so could be correct.
With that much power being used, it would generate some heat one would think,
but I guess being submerged in fuel would keep it cool.
Mine lasted over 200K miles with consistent filter changes.
All that being said the only moving part that could generate noise is
the pump. Be sure to tie wrap the fuel connections tight so they don't pop
off. Speaking from experience. And I did not want to mess with an off brand on
something as critical as this.
What brand filter did you use? And also how did you measure the current?
If I were you, I'd borrow a fuel pressure testing kit from ORiely or buy one, 20 bucks from
Harbor Freight. (You'll need plumbing tape on that also, not included)
see whats what. And if it's looking shady pick up a pump, looks to be about $200 for genuine.
A gas tank tool like this...https://www.tooldiscounter.com/ItemD...iABEgKKHPD_BwE
Local auto parts store should have it as well.
Some tie wraps and a tie wrap tightener and keep it in the car along with some tools just in case.
No brand name? I've used Bosch, Hengst and Mann...all have been fine.
Wow, holy crap you measured the current right off the pump,
is that safe to do? Thought perhaps you did it from the fuse.
It's safe to do it from the pump.
I don't think the issue is from the fuel filter. I was hoping someone has information on what amp the pump should pull from this particular car.
I doubt anyone has ever had the occasion to check it. I for one would
a. not connect the battery with the access cover open and run the pump and
b. never put anything electrical near the open fuel tank
So...good luck.
I don't pray much but I said a couple hail mary's before I did that job, and of course opened all the windows and the hatch to keep the air flow going, and a fire extinguisher handy. Also had someone keeping watch in case some idiot walked by with a smoke burning, divert them away.
Gas stations have signs saying cell phones can cause explosions...why wouldn't an Ampmeter
be a hazard? Well...I wouldn't do it.
So...good luck.
So...good luck.
So...good luck.
If what you say is true then it shouldn't have electricity to run the pump.
