Radio Reception Problem update, need help
Old Jun 8, 2004 | 10:26 PM
wherman's Avatar
2001 C320
I have taken my car into the dealer a few times for bad reception on FM. The last trip the "R&R Antenna Amplifier, Clean all contact points." The problem has gotten a bit better on some stations and worse on others. Today while searching the forums I tried to "press in" the antenna to the rear glass with no success. Finally I was wondering if it was something else and started to futz with the HU.
When I moved the sound all the way to the front in ambient mode it only came from the center speater (The same area as the windshield vent). When I turned off the Driver/Speech/Ambient modes and had it full front there was no sound at all.
My question is this, is that normal? I assume no.
If not, could I have a bad HU and then that could be causing the reception problems?
Thanks for all the help guys and gals.
-Bill
Old Jun 8, 2004 | 11:18 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
if you want way better sound get an audio10.
Old Jun 8, 2004 | 11:20 PM
wherman's Avatar
2001 C320
It's not about sound quality, more about reception quality.
Plus, if there is no sound in the front, that seems to point to a bigger problem that I may not fix with an audio10 at which point my dealer will not touch under warranty because of my futzing with it.
Thanks though.
-Bill
P.S. I would get a COMAND instead
