Rear door not opening from outside!
Old Oct 16, 2018 | 09:47 AM
Mikesbaron's Avatar
2005 C230
2005 C230 Sport Sedan
The other day went to open the left rear door and it would not open. I hit the unlock on the fob and inside car and nothing. The lock stem thing wouldn't even go up or down (it was in the down position). When I tried to pull the stem up manually it didn't seem to be attached to the metal part of the stem. I then pull on the outside handle a little hard and the door opens part way, it's still partially latched. Another quick tug and it opens.
Funny thing is that it will open just fine from the inside. Any ideas on what could be happening?
Old Oct 16, 2018 | 02:52 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
New one on me.
Not sure if what you're describing is issue with door latch, or the electric unlock mechanism or both?
Pull the door panel off for a closer look.
We replaced the lock/unlocker on our ML.
What a PIA and expensive.
Old Oct 16, 2018 | 03:42 PM
Mikesbaron's Avatar
2005 C230
I just find it weird that the inner latch opens just fine but the outside one doesn't so well. Is the outside handle electric and the inner not?
