Audio 20- intermittent no sound
It's doing the classic radio/cd/etc on but no sound that the HK people get when the amp goes out but I have no HK, Command, phone, or CDC. I have the most basic Audio setup that you could get for 2007. The weird thing is that if I pop open the passenger door, the sound kicks back on like nothing is the matter and carries on after I shut the door and until the car is turned off. Naturally, my thoughts are that that theres something amok with the wiring harness between the chassis and the door. I've done a few thread searches but haven't come up with anything on here similar to this or perhaps I just need to be better with keywords.
Has anyone dealt with an Issue like this? If not, can someone check my assumptions before I go tearing into it:
- There aren't any external amps involved with the base audio system so there shouldn't be any fiber optic cables going into the door?
- The speakers are run by basic +/- wires leading directly to the head unit?
- If one wire gets pinched/grounded, can it kill the audio for the whole system?
- Theoretically, can I just solder in fresh wires between the speaker connection in the door and the speaker wiring in the chassis?
- Should I try the fuse reset thing before I start running new wires?
- Or am I egregiously missing something else here?
Thanks in advance for any insight here. Other than this, the car has been pretty spot-on other than a couple suspension bushings and a wheel bearing.
Ultimately if cut out permanently about 15 mins into an hour drive and the door trick didn't fix it. Out of frustration, I grabbed the rubber loom between the door and the chassis and moved the internal wires around a bit and viola, sound came back on. Evidently there is a sketchy wire in there someplace but it hasn't acted up in almost three years so I never bothered to track it down lol.
