C300( W204) wheels on C230
2005 E55 AMG
What size spacer should I use to make these fit on my 03 C230 sedan? The rear tire are rubbing on the plastic wheel well lining near the shocks. Not alot, but enough.
I am thinking 15mm spacer. Also what length lug bolts will be needed?
" sorry trying to attach photos but having problems "
. The wheels in question are factory w204 wheels...17x7.5 front...17x8.5 rear. The front fits fine...the rear is rubbing.
The point is that the w204 wheels are drilled out for M14 bolts and M14 ball seat. You need M12 bolts with an M14 ball seat. The length of the bolt shank is yet another issue. Your best bet is to ask about the length on a w204 forum but you still need that specialized Bolt. There are vendors out there selling this type of Bolt.
