For Those With Coilovers
03 C320 (For Sale), 08 Audi TT
Currently I'm running 19x8.5f (235/35/19) and 19x9.5r (265/30/19) with a 32 offset. I'm going to install H&R coilovers soon. Is anybody running the same setup and if so did you have any problems with rubbing? Somebody mentioned that depending on wheel size and offset I may need spacers. Thanks.
The True OG Modded out W203
Re: For Those With Coilovers
2008 C300 Sport
Even with HRE's and running coilovers I still needed to run a 5mm spacer because the sidewall of my tire was rubbing against the CO spring... I can't say for sure if you need a spacer or not because other things factor in like brand of tires and how low your CO's are set and such... you won't be able to know for sure until the CO's are actually installed on your car...
Thanks for the info. I've tried to post pics of my car but I can't load them even at 1 megapixel which I believe is the limit.
