Help!! 200 kompressor starts and dies!
I bought my first ”newer” mercedes a 203 200 kompressor and i have some problems that i cant figure out
symptoms: car starts but after 1-2 sec it coughs and dies , had no faultcodes until i changed out the camshaft position sensor and gets the code :P0340
selutions i have tried: changed injectors, sparkplug, camshaft position sensor, ”camshaft magnet adjuster”, fuel filter, coils and MAF.
i am all out of ideas and this is my only car and i realy need it, need all the help i can get!
thankfull for eny awnsers sorry for my bad english /Johannes
Is it the M111? Have you checked the fuel pressure? There is a valve at the fuel rail under a black screw cap. Push the pin to check if fuel comes out. The fuel pressure is not checked from the M111 ecu.
