Hood replacement
Old Nov 20, 2018 | 08:29 PM
Insbroker's Avatar
Clk320, 300sl, 500sl
Hood replacement
I didn’t find anything by search so I’m hoping someone has the answer I have to replace the hood on my 2003 c240. I have removed 2 screws holding the rear on hood grill that covers the windshield washers. I think there is still one in the middle on top but it’s covered and before I pop it off I want to be sure that is the screw cover and not a sensor of some kind. Anyone? Thanks
Old Nov 20, 2018 | 09:06 PM
BF_JC230's Avatar
2005 w203 C230
If you’re trying to remove the hood grille, and that is what you’re asking about here goes...
There are three screws accessible under the hood. One on each wing and a central one. There is no cover, you maybe looking at and thinking the solar sensor, or more likely dummy blank dome (on top side) is hiding hardware- it’s not.
But, removing the grille from the hood is a PITA. and, I hate to tell you this, but most likely you will break the/some plastic clips.
Look down from above, in the corners and around the perimeter - you will see the little square pockets that say, “push me forward and down to release me...” but...they’re thin wall plastic above engine heat and under sun rays...they break.
I’ve been told having a helper helps.
Search “Solar Multifunction Pollution sensor retrofit, mod, etc.”
Old Nov 20, 2018 | 09:16 PM
Insbroker's Avatar
Thank you. That was the information I was looking for. I’ll have to look a little harder for that 3rd screw.
Old Nov 21, 2018 | 01:26 PM
BF_JC230's Avatar
2005 w203 C230
You're very welcome! That's why we visit here!
https://mbworld.org/forums/c-class-w...control-2.html
https://mbworld.org/forums/c-class-w...auge-05-a.html
https://mbworld.org/forums/c-class-w...rade-plus.html
Old Nov 25, 2018 | 03:31 PM
Insbroker's Avatar
I did as you said and it worked and as you said every clip broke. 8 haven’t looked yet so I’m hoping I can buy replacements! Thx again for the correct advice
Old Nov 25, 2018 | 09:05 PM
BF_JC230's Avatar
2005 w203 C230
0019911670
A0019911670
Old Nov 26, 2018 | 11:12 AM
Insbroker's Avatar
Thank you again!!!!! Much appreciated.
