battery removal
Old Jun 20, 2004 | 12:33 AM
mperl93's Avatar
c230 sport sedan
battery removal
Is it safe to remove the battery from a 2004 C230 sedan? Is there reprogramming process that must be done on the computers after the battery is disconnected?
thanks,
Mike
Old Jun 20, 2004 | 01:23 AM
outie's Avatar
2011 M3 ZCP, 2022 Porsche Taycan GTS, 2018 Tesla Model X, 2023 McLaren 720S Spider
I think you are referring to the radio code required after disconnecting the battery? Yeah you probably need to enter the radio code back when you conenct the battery...
Old Jun 20, 2004 | 01:51 AM
Steve Clark's Avatar
C32AMG
There is a way around this...
All you need to do is connect a 9 volt battery into the system just before you unhook the car's 12 volt unit.The 9 volt trickle is enough to keep the radio's memory intact until you reinstall the 12 volt battery.
I've even seen kits to accomplish this that simply connect through the cigar lighter receptacle.Ask the parts guy/girl at any major auto-parts store.
Old Jun 20, 2004 | 03:12 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
No, W203 audio systems do not require any codes to be re-entered. It is therefore safe to disconnect the battery. When reconnecting the battery, make sure you have all connectors plugged into the head unit - otherwise it will lock itself up.
Old Jun 20, 2004 | 01:57 PM
levelr123g's Avatar
WRONG WRONG WRONG.
Just unplug the battery and then hook it back up. the radio DOES NOT require a code to work.
Old Jun 20, 2004 | 03:02 PM
SUNILP's Avatar
2015 E250D
I have removed the battery several times and there is no need to enter a radio code. I have removed my comand several times also with no problems.
