w203 1.8l kompressor issue
Old Feb 4, 2019 | 07:21 AM
Darius Baronas's Avatar
MB C220 W204 FL
Hello. First time trying to figure it out what is wrong with that type of engine. STAR diagnostics shows 2029-01 ( or somethimes 2029-02) fault. Engine running normal about 3-5 mins when engine is cold. After that it start jerking and mostly stops. Checked vacuum pipes for air leak - everything is good. I found oil in the O2 sensor plug (no oil from camshaft magnets or in the other places), removed it with air, after that i have had 2038 - 001 fault. Changed O2 sensor, now remained same 2029-01 fault . If i remove hose from compressor , then engine starting work normally, Need advice what to check and how to find problem..
Cannot upload video here, so uploaded into wetransfer :
https://wetransfer.com/downloads/e1e...4121953/4e3bd5
Thank you guys
Old Feb 21, 2019 | 05:39 AM
MB C220 W204 FL
No one helps... But problem solved. Crankshaft sensor changed and now everything is ok
