Need advice (Stripped Screws)
2001 C320
Today I got my 05 side mirror blinkers from Steve and went to install them.
Well much to my dismay, when I took off the mirror covers 3 out of 4 screws were already stripped. You can tell that someone or something (Assembly robot??) over torqued the scew because the plastic around it is all cracked.
Should I bring it into the dealer and ask them to take care of it under warranty, and does it even fall under that?
Or is there some way to remove the screws myself?
Thanks,
Bill
Thanks,
Bill
Missing my beloved Benz
my thoughts
In the past when I stripped screws, I used my needle nose Pliers. A needle nose pliers is, a hand tool with two hinged arms ending in jaws that are closed by hand pressure to grip something. I gripped one end in the center of the screw and the other, on the outside. At the same time, I'm turning it. Lefty loosey, righty tighty (saying I learned as a child).
Hope that helps.
Sincerely,
James Sell
Hope that helps.
Sincerely,
James Sell
2001 C320
Re: my thoughts
Hope that helps.
Sincerely,
James Sell
Hope that helps.
Sincerely,
James Sell
Bill
2001 C320
Originally posted by electromethod
go to sears. I have these reverse bits that take out stripped screws. Here is the link........i have used them a lot. in fact, so much that I leave them in the tool box in my truck so I don't lose them.
sears
sears
Thanks,
Bill
1 Post
Debadged 6-Speed '05 C320 Sports Coupe
Try a flat blade device, inserted underneath the screw head, to lift the screw, while rotating CCW.
For replacement, any standard filling two-part epoxy may be used to reinforce the cracked plastic. It would be possible to create an epoxy fillet around the outside of the plastic boss. It is also possible to fill the screw hole with epoxy, then drive the screw into the hole, prior to it setting up, all to strengthen the cracked areas.
2001 C320
Well, next problem now. I just called the dealer and asked about replacement screws (If I take them out, need to put something back in). They don't show the side view mirrors as having any screws. So I'm heading over there to have them try and match them to what they have in stock.
-Bill
-Bill
2001 C320
Well, after driving around a bit today, no one sells the screws. Also, no one thinks I'll be able to get that small of a screw out. So now it looks like my $60 retrofit just became a $$$$ project. Anyone know what the mirror housings go for? The dealer thinks that is the only way to get the screws.
-Bill
-Bill
2001 C320
Originally posted by CitronC230K_03
well if you are changing over to W211 blinkers buy W211 housings so you can utilize the puddle light eventually.
'01 ML430, '03 C320 Coupe MT, '14 GL450
Have you tried to have them replaced under warranty? If your car is still under warranty I would definitely try that first. You don't want your mirror (if you kept it) to fall apart at 50,001 miles. Speak to your SA and see what he says...
When I was looking to replace the grill on our ML430 with the ML500 chrome stripped one, before I took off the old grill, I noticed that a couple of the plastic tabs, where you fasten the grill to tbe hood, were broken. Probably from vibration and the heat of the radiator. I took the car to the dealer before I did my mod, and they replaced the grill under warranty, no questions asked.
2001 C320
Thanks,
Bill
sounds fun
sounds like you are having fun. I would just say heck with it and leave the car the way it is now. lol You should see the kelly blue book value. I almost had a heart attack when I saw it. I thought benz's had alittle more trade in value.
