Are pedals adjustable?
Old Apr 24, 2002 | 07:08 AM
hrh's Avatar
hrh
C230K
Question Are pedals adjustable?
Hi all. I know manufacturers tend to keep the pedals apart to avoid ending up on 20/20 al-la the old Audi 5000, but my question is are either the gas or the brake pedal adjustable from side to side? I'd like them a little closer for better reach when trying to bring the revs up under braking.
Old Apr 24, 2002 | 07:39 AM
DtS's Avatar
DtS
C200 Kompressor
I hardly believe they are adjustable. Mine seem to be pretty fixed anyway... And just for my own curiousity: why would you like to keep the revs up under braking
Old Apr 24, 2002 | 07:58 AM
hrh's Avatar
hrh
C230K
I should have specified that I'm interested in adjusting the brake pedal distance to the accelerator on a MANUAL car:
For matching engine speed to transmission shaft speed, so as not to make the downshift too abrupt or fry one's clutch when choosing the gear for powering out of the curve after you've finished braking for it.
Old Apr 24, 2002 | 09:09 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
One possibility
Strictly speaking, no, they aren't adjustable. But, what you could do is get a pedal set that will allow for easier transitioning between brake and gas.
For example, I have a Brabus pedal set on my ccoupe - they all attach via screws, so you could position the brake cover as far over to the right as possible. That might help.
You could also try other brands of pedal covers to see if any are large enough to give you the setup that you want.
Old Apr 24, 2002 | 10:57 AM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
Yeah, autozone, pep boys, advanced auto etc have many different kinda of pedal kits that screw on. Just place them as close as possible to each other as you can. Hope it helps, and post pics if you can.
Old Apr 24, 2002 | 11:01 AM
young's Avatar
GLB 250 4matic
i just heard a story about ford taurus? that talked about the gas and brake pedals being too close... causing some drivers some problems... http://www.auto.com/industry/iwirg23_20020423.htm
Old Apr 24, 2002 | 01:15 PM
hrh's Avatar
hrh
C230K
Don't let those Taurus folks near a Formula car!!
With most formula fords, you have to bring your knees together to be able to hit the brake WITHOUT hitting the gas, they're so close together. After a few hours at Skip Barber, I had bruises from where my legs/knees would hit each other, or the steering column from doing this so often!
Thanks to all for the new pedal cover suggestion, but I love the C7 pedals. would hate to lose `em. Problem I'm having is not when I'm wearing sneakers (they widen out at the front), but dress shoes when driving to/from work.
Old Apr 25, 2002 | 09:09 AM
mdp c230k's Avatar
2002 c230k
Yeah, the pedals are far apart for any heel-toe action unless you have swivel joints on your knees! It can be done but it takes a little more effort than I would like to use. Post any pedal mods you come up with if you can.
Old Apr 25, 2002 | 07:30 PM
KJ-TypeR's Avatar
M3
Another thing that contributes to this problem is that the gas pedal is MUCH closer to the floor than the brake is. Even if the pedals were closer together, I think it'd still be harder to heel-toe in the 230K than it would in a "normal" car.
Old Apr 26, 2002 | 12:50 PM
Mark08859's Avatar
2008 C300 Sport
I guess that means double clutching in order to downshift.
