Clarification on Post, TC & Pan Drain & Refill
Old Mar 26, 2019 | 07:51 PM
Ryan.tim.j's Avatar
2009 Mercedes E320
2009 MB E320 with 722.9. Do you put all 9 or 10 L of fluid in before starting car? One of the posted docs from original post says fill 6, then start, then add 4. If you shove in all 9 or 10 before starting, does the fluid get pushed into the TC? Does seem like some fluid should be in TC before starting engine, don’t want to run a pump dry if you don’t have to. Definitely does not seem to be room for 9 or 10 L in the pan underneath transmission.
