door trim questions
Old Jun 26, 2004 | 03:51 PM
cclass320's Avatar
door trim questions
some questions about the door trim pieces... ive searched "door panel removal" but the one i found were not too detailed...
i found the bolt under the SRS badge, and the c shaped thing on the door hinge... but i cant locate the third bolt thats supposedly under the door handle?
any pictures/pointers will be appreciated!
Old Jun 26, 2004 | 04:40 PM
SUNILP's Avatar
2015 E250D
you have to remove the handle off by popping it out. There are 2 bolts under that. IF you can notice, the door handle is actually 2 parts. pop off the outer part with a dull item.
Old Jun 27, 2004 | 07:09 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
so there are a total of three bolts holding the panel on. what holds the rest. plastic clips? is that what you mean sunman by pulling the panel off with a dull item. are these three items the same for a coupe door?
