Limp mode with P0715 and P0730 codes
Car going into limp mode again
I’m back again... after replacing the conductor plate and the TCC it started slipping again about 2 days ago. Got the 2502 and the 220A codes all over again and I’m frustrated. Could it be because i didn’t put enough ATM in it? I drained 4.5 but didn’t include the ATM on the ground and what leaked from the car. I’m starting to feel like it’s becoming a money pit. I love my car but i May have to sell it. PLEASE HELP!
I did after I first changed it. I reset the codes the first time and it drove fine up until i hit the drive thru at Wendy’s. Probably about an hour. Then it stalled. But it took like 15 mins for the CEL to come on. I cleared the codes again last night but i drove my friends car and let it sit.
#33
It was stopped at a redlight but in drive. I pressed the gas and it just reved up with no acceleration. I turned the car off and then turned it off again and same thing. It didn’t lurch forward that i can remember.
#34
Update: so i had my car off for a few days. I drove it today and i noticed a whining sound as the transmission heated up. The gears jerked a little as well. So i checked the transmission fluid level, and it was on the last line of the 80 mark. I’m going to add another quart and see if that makes a difference. Any help?
#37
#39
Same problem ,same error codes..
Hi ..
Thanks to you , that I have solved same above problem in my car c230k..
I just followed the advices you offered to get rid of limp mode with same errors above mentioned..
I really did not go to any mechanic for fixing..
I did not trust , because everyone one tells different story to get more works and must money out of it..
before I crossed with this blog, I started
with dismantling Conductor plate , cleaning valves body , Check valves .. changing ATF (5L).
After that ,Still having same problem ( limp mode).
Went to open gear shifter to inspect ,, nothing to find..
Than I opened the TCM to see if oil leaked to there,, it was clean..
Than , I went to check forums in websites.. to find your remarks of DELETING THE ERROR CODES..
no sooner I did it , than everything went good.
Thank you for the info.
