Coolant tank
Old Apr 22, 2019 | 05:20 PM
Brenden712's Avatar
Mercedes benz c230 Kompressor
Coolant tank
Why is it that after i drive my coolant tank leaks out a decent amount of water?
Old Apr 22, 2019 | 05:36 PM
5by5's Avatar
2011 C300 Sport 4matic, 2005 C240 4matic, 2003 C230K Sport, 1999 C230K Sport, 1969 220D (first car!)
I’m not sure I understand. Do you mean to ask why coolant flows from the cooling system to the expansion tank or are you saying it leaks from the tank?
5by5
Old Apr 22, 2019 | 05:43 PM
Brenden712's Avatar
It leaks from the tank.
Old Apr 22, 2019 | 06:54 PM
5by5's Avatar
Is it overfilled? If not I’d look for a crack in the hose fitting. It may open up under pressure.
I had this happen on a 2004 VW Jetta. Couldn’t find the leak until it let go. Seems like I replaced half the fittings in the cooling system one by one...
Old Apr 22, 2019 | 07:05 PM
Brenden712's Avatar
Ok sweet i’ll definitely check it out. Thanks!
