Water
Old Apr 23, 2019 | 03:33 PM
Brenden712's Avatar
Mercedes benz c230 Kompressor
Water
Ok so i have a 2002 c230k and it had an overheating issue so i put a new thermostat in it and it seemed to help. But now when i go to drive it i check the coolant and there’s non in the tank so i fill it up with water then after i drive about a mile it leaks water from the cap. The whole coolant system is messed up on my car. Can i see some pics of your guys’ engines or if anyone has a link to a diagram??
Old Apr 23, 2019 | 06:56 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
If the reservoir is draining itself you have quite the major leak. Your car should basically be shooting coolant everywhere.
Wipe down the engine and start the car again. The leak should be really obvious. And I'm not talking about the cap either. The cap drains from the top of the tank. You have another leak somewhere else.
Old Apr 23, 2019 | 08:46 PM
5by5's Avatar
2011 C300 Sport 4matic, 2005 C240 4matic, 2003 C230K Sport, 1999 C230K Sport, 1969 220D (first car!)
Hi Brendan,
I see that you’ve started several threads about the cooling problems on your new car—sorry to see it’s not resolved yet.
In an earlier thread I wondered if you have a blown head gasket. If you’re going through a lot of coolant and can’t find an obvious leak, it might be going out the tailpipe.
A head gasket leak can also cause a lot of pressure to build up in the cooling system. You might try running it with the coolant tank cover of and see if there are a lot of bubbles coming out, especially after the car warms up.
I went through very similar symptoms on my W202 with the M111. I know you’re avoiding the thought of a blown head gasket but I’d check it out before throwing away more money on parts. Go to Autozone (or similar) and borrow their test kit and check it out.
Replacing the head gasket is a time consuming job but doable as a diy. I think mine was about $200 for the gasket kit and head bolts and another $100 to have the head checked and skimmed. On the W202 it was one day to remove, a few days in the machine shop and another day or so putting it back together. Ymmv.
5by5
