2006 Mercedes C280 4matic stuck in 1st gear and in sport mode
Old Apr 27, 2019 | 02:48 AM
Royal Music's Avatar
The problem started when i was driving. I had it in D and was bump shifting. Went to bump up to 3rd when i felt a hard shift after that it was stuck in 3rd. I turned the car off and on and put it back in drive. I tried to bump it to the left to go to 1st gear but its stuck on D in 1st or 2nd gear and i cant change from sport mode to comfortable mode. Any help ??
Old May 1, 2019 | 08:19 AM
w203ck's Avatar
2006 C180K, 2004 E200K, 1996 Mercedes E320
Your car may be in limp home mode. The only way to get the transmission to shift normally could be a reset of the modules using diagnostic software.
This is what I did when my transmission wouldn't shift after a battery replacement. Also try to disconnect the negative terminal on the battery for 5 minutes to see if it could revert back to factory settings.
Old May 1, 2019 | 06:40 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Have you used a scanner to pull codes? Is the check engine light on?
Old May 27, 2019 | 04:29 PM
I have only used a obd 2 scanner and got a code for my cats since i got them cut off and that keeps my check engine light on
Old May 27, 2019 | 04:32 PM
When you had your battery replaced could you change from C to S mode or was it only your transmission not switching gears? And I will try disconnecting the negative terminal to see if it helps. Thanks
