Engine stutter 200 Kompressor
Old May 13, 2019 | 11:39 AM
Cannoon's Avatar
W124 300E 1991
Hi!
I have a 2001 W203 C200 Kompressor that stutters. I can hold the throttle stable, when it suddenly cuts for some seconds, before going back to normal again and driving just fine.
It misfires often when taking off after driving, like in an intersection. If i rev it high while at standstill it cuts off when the throttle is released and the revs go down.
Any ideas on what this is? Tried diagnosing (launch creader v++) but got lots of wierd codes that werent in the system and i couldnt find (P201d-000, P201b-000, P203b-000, P200b-000).
I've wondered if its the TPS, but im not sure, might it be as simple as sparkplugs?
Old May 13, 2019 | 02:37 PM
Cannoon's Avatar
W124 300E 1991
Its the M111 engine if that helps
Old May 13, 2019 | 02:46 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
With that many codes your best option might be to pay $100 for a diagnostic. Unless you have access to star.
Misfiring can be plugs, bad coils/wires, failing injectors, clogged fuel filter, bad fuel pump etc etc.
