2din radio
Old Jun 26, 2019 | 02:46 PM
Matija Bencic's Avatar
W203
2din radio
New 2din installed,and its overheating,due to too much ohms in speakers?
Old Jun 26, 2019 | 11:17 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
Which brand and model did you install?
Old Jun 29, 2019 | 04:46 PM
W203
Answer
I dont know some from china,i asked a proffesional he explained to me,i need to change speakers or disconect some
Old Jun 29, 2019 | 11:54 PM
KevinH2000's Avatar
I’ve read that the stock speakers are rated at 8 ohms. Most stock systems use 4 ohm speakers. See this article for background information: https://www.lifewire.com/speaker-impedance-3134705. Any good quality system should be able to drive 8 ohm speakers.
Do you know whether your car has a factory amp? Is it possible that you have connected your head unit to the amp and not directly to the speakers?
Old Jul 1, 2019 | 05:33 AM
W203
Answer
i think i have an amp,because i have factory subwoofer in trunk...
probably all speaker are connected to the amp,and then back
Old Jul 1, 2019 | 08:05 PM
KevinH2000's Avatar
Most head units have two sets of speaker outputs. One set is designed to connect the amplifier in the head unit directly to the speakers. The second set provides an un-amplified signal to an external amplifier which in turn connects to the speakers. If you have connected the amplified signal to the car’s amplifier that may be the problem. I suggest that you post a photo of the back of your 2-din unit. That may help me to see what you have.
