ESP, BAS, Break wear, Car stuck im Park. W203
Old Jun 28, 2019 | 09:02 AM
BrianMako's Avatar
W203 2006 model
My car is stuck in park, the break lights are off, dashboard showing esp, abs and speeedtrinic sensor faults and speedometer equally not working. I connected it to the icarsoft i980 and I got codes P1876 reading as "the signals sent by control unit N47-5 (ESP and BAS control module) for the wheel speeds and braking torque are not available on the CAN bus" and also code P2012 reading, "the brake signal from control unit N47-5 (ESP and BAS control module) is not available on the CAN bus.
What could be the problem?
Old Jun 28, 2019 | 11:37 PM
RedGray's Avatar
2005 C230K Sport Coupe
It's likely that your ABS unit isn't talking to the rest of the CAN bus.
It could be a bad ABS unit, bad wire, bad connector, fuse, etc.
https://www.benzworld.org/forums/c21...lfunction.html
Also, it's "brake", not "break".
Good Luck!
Old Jul 2, 2019 | 10:43 AM
BrianMako's Avatar
W203 2006 model
Good Luck!
How best can these possible causes be tested individually if you have an idea except for the fuse?
Old Aug 11, 2020 | 12:29 AM
tomoguek's Avatar
2005 C55
Hey
Did you have any luck solving this? Got the exact same thing in my 2005 C55
