Multiple cylinder missfires
05 C230 Kompressor
Scanner shows multiple #1 cylinder missfires.
This is a intermittent problem but happens randomly and frequent.
When it happens it will run rough etc(BUT) if you (RESTART) it will all be corrected untill the next time it happens.
I've changed plugs/MAF/ etc etc, even went as far as swapping out an ECM .
Swapped coil packs, no change the problem stays with #1 cylinder.
I'm stumped, all input greatly appreciated!!
What really blows my mind is when it's restarted...it runs excellent!!
