05 Radio Control via Steering Wheel
Old Jul 12, 2004 | 11:01 PM
coppermine's Avatar
2001 c320
How come we can't use the steering wheel buttons to cycle through our preset radio stations for the 05 model? The steer wheel buttons only goes to the next radio station that it can get. Any response would be greatly appreciated.
Old Jul 12, 2004 | 11:07 PM
preyx's Avatar
'02 C230K Coupe
Dunno if this had changed with the '05s, but on the older models (mine is '02) there was a setting in the config menu that you could switch between seek and memory modes. Poke around there and see if you can find it.
Old Jul 13, 2004 | 12:49 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
AAAAaaaahhh!
-s-
Old Jul 13, 2004 | 01:17 AM
coppermine's Avatar
2001 c320
I've checked the manual and it didnt state anything--any other 05 owners have the same problems or want to chime in?
Old Jul 13, 2004 | 03:28 AM
i7iceguy's Avatar
2010 E350, 2007 S550 - SOLD, 2007 ML350
i have the same problem i looked through all the settings and cannot find any. do you have the audio package?
Old Jul 13, 2004 | 04:57 AM
mike82y's Avatar
u will have to enter the setting first.. then you can choose between.. searching or memory
hope this helps,
mike
Old Jul 13, 2004 | 08:49 AM
mctwin2kman's Avatar
It is in the MFD settings, at least in the 2003. It was set from the factory to use the seek function and not presets.
Old Jul 13, 2004 | 11:04 AM
i7iceguy's Avatar
hope this helps,
mike
what do you mean you have to enter the setting first? this is for 05 model btw.
Old Jul 13, 2004 | 12:32 PM
Turbo2's Avatar
I tried today on my '05, even went through the manual trying to figure out how to do it. If anyone could give a step by step process that would be great, it would be much easier to go through the preset tuning via the steering wheel.
Thanks.
Old Jul 13, 2004 | 01:52 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
change it in the MFD. it should be the first option in the convienience option.
Old Jul 13, 2004 | 01:56 PM
Turbo2's Avatar
CitronC230K-
I tried it under the convience area, but there is no option. What should it say, or what does it say on yours is the questions.
Thanks for the help.
Old Jul 13, 2004 | 07:44 PM
SUNILP's Avatar
2015 E250D
My 03 has it in the convience settings menu. If you are new to using the menu in the IC, it may take a while. It is confusing at times. On mine, I can set the buttons to change to memory presets or just to the next available station.
Old Jul 13, 2004 | 09:10 PM
coppermine's Avatar
2001 c320
I don;t think the 05 has this option anymore--my service advisor was helping me on it and he couldn't find it as well. What a bummer.
Old Jul 13, 2004 | 09:45 PM
SUNILP's Avatar
2015 E250D
I can't believe it's gone. I heard the new w211 also does NOT have this feature.
Old Jul 13, 2004 | 11:24 PM
Turbo2's Avatar
This is a huge disappointment, how much money can this save MB (if any)? I would think spending the time to reprogram the system and remove this option would take more time (read- cost money) then using the same software in the '04's and other previous models.
Huge disappointment.
Old Jul 14, 2004 | 04:09 AM
LorinserCClass's Avatar
The True OG Modded out W203
buwahahahaha!! Ya'll got stiffed like I did with my W211!! I cant believe on a 57K car it did NOT offer that feature yet on my 35K 2001 C Class it did, Go figure
Old Jul 14, 2004 | 10:50 AM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
here...
this is how for my 2002....... im not sure it its the same for the 04 or 05
scroll to the setting menu
press UP arrow (left side button above scroll forward/reverse buttons)
then a new screen that reads
instrument cluster
lighting
vehicle
should appear
use the volume down button (right side of steering wheel) to scroll down and highlight VEHICLE
AUDIO MODE OPTIONS should appear that reads
station search
memory
use the volume down button to highlight MEMORY.
again... that should work all the w203 models up to 04.... but im not sure for the 05's w/ the new interior (not sure if its the same VDO junk)
-carino
Old Jul 14, 2004 | 08:39 PM
accbenz's Avatar
2005 C230WZ
for some reason, Benz did away w/ that feature in the 2005 C Class...but they added some other stuff such as automatic summer/winter time change, which is convenient, but who know's why they can't do both.
Old Jul 14, 2004 | 09:13 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I read somewhere that the sunroof now closes once the rain sensing wipers are activated thru rain. Can someone confirm this. Hey sunman; here is another mod for you if its true.
Old Jul 14, 2004 | 09:41 PM
SUNILP's Avatar
2015 E250D
Well, if it is software controlled then it will be hard. I don't think my 03 does this but I have never tried it.
Old Jul 14, 2004 | 10:20 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
So, this must be one of the things MB "simplified". Looks like they have overdone
Old Jul 14, 2004 | 10:23 PM
vadim's Avatar
Not enough memory?
Old Jul 14, 2004 | 10:52 PM
i7iceguy's Avatar
i dun understand why mb would do this? the steering wheel control is pointless at this point hehe
Old Jul 15, 2004 | 01:38 PM
i have the auto time change already thru my COMAND.
Old Jul 15, 2004 | 03:35 PM
scorchie's Avatar
If it is software controlled, all you have to do is find the controller that is responsible and replace it.
More and more of the stuff in the car moves to controllers on the network telling other devices what to do. For instance, retrofit of active cornering headlights requires replacing the headlights (no kidding) and the headlight height adjustment module. The rest just works, because on CANBUS there is already steering angle sensor (for ESP) and speed signal (for so many other things). So the new module just reads this, does its computations, then tells the headlights where to move.
The whole radio thing sounds like such a simple oversight and everyone says how EASY it would be to fix... but you know, it must not be easy to fix... because it hasn't been fixed yet. Why not? Well, the new radios are all made by Harman Becker (and Siemens in the high-line cars). The older COMANDs were made by Bosch. Sometimes in software development, you get so far down a path that to go back and change something that was "already there" becomes quite difficult and therefore not cost effective... and this may have happened when adapting the new head units to the Mercedes CANBUS interface.
I can provide an example of this. Netscape Communicator 4.x had a really neat feature called "roaming profiles" that means you could go from computer to computer (like desktop at work, laptop, or home computers) and have all your settings and updates, like new bookmarks, etc. follow you to each computer. Then when version 6 came out, it had disappeared. Now as of version 7.1, it still has not appeared. Checking the development information, you'll find that there were some changes to the way underlying functions work, and those change would make the roaming profiles require a complete rewrite to work now. I guess I don't expect most of you Windoze zealots to understand, but it's a reason, and it is how it is.
Will it change? Maybe someday. Any by then, you'll be able to buy a new COMAND from Steve.
-s-
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
