Is CPS failure common on 203s?
Hey Guys,
My ‘02 w/ 69k miles refused to start in my driveway last week after driving a good amount in the morning. It cranked after a couple hours; I had no issues starting for the next couple of days and then it completely refused to start. Code P0335 was stored when I checked w/ my OBD scanner. I ordered a Bosch replacement from Amazon and had it towed to my mechanic. He charged me an hr labor, it kind of looked like a pain to replace without the proper tools.
I stumbled across a post from one guy who said he keeps a spare in his car because failure is so common on 203s. I’ve owned quite a few MBs in the past, this is my first 203 and the only time I had to replace a CPS. I’m interested in finding out the general longevity of this part? I can only assume a genuine Bosch part lasts longer than some of the inferior mfgs out there.
Cheers,
-Rob
Cheers,
-Rob
MBworld Guru
CPS failure is an odd thing. I;ve personally never had one fail, but I know many who have. I have a theory that it's not the CPS itself, but slight variations in the distance between it and the flywheel pulse ring.
The tow driver dropped it on a flat surface at the shop; I attempted to start w/ no success. I requested the tech clean the female plug before installing the new part. I can only assume everything has to be spot-on for a CPS to function properly. Knock on wood it has been running fine after the replacement.
Cheers,
-Rob
Hi guys
I've replaced the fuel pump, the fuel filter and cps. Still no solution.
In a nearby market. I could not get a brand new cps as those are really scarce over here. But the technician working on the car said something about the earth coming from the ECU isn't reaching the cps. Probably fault might be from the ECU. Got any help on that? Thank you.
I'm having a major issue with my w203. It cranks like forever and refuses to start. Sometimes especially when it's been parked for quite a while and cool, it starts normally. Its so bad right now, I cant even use the car.
How old is your battery? The simple things like this sometimes get overlooked.
I did d write trace and nothing was found
All wires were intact.
Had to buy a new ECU with ignition and key, and boom, my car roared back to life.
But now, my windows won't go down or come up.
They're stuck.
The switch on the driver's door don't work right now.
Please how do I correct that.
It was working perfectly fine prior to the ECU replacement.
Hey man
They're stuck.
They're stuck.
Sounds like your window issue requires the reset procedure similar to when a new battery is installed. GL
Welcome to Inside life.
Please how do I go about this reset procedure?
MBworld Guru
I would start by checking fuses for the door controllers and windows. But given that you replaced the EIS (I assume with a used one) it could be defective and not sending the appropriate wake signals on the CAN bus. There is no coding (or lack thereof) that would cause the windows to not work.
I went back and got it recoded or reprogrammed or whatever they did to it with them computers.
Now it's working perfectly.
Got my car back
Everything is ok now.
Thanks guys. I really appreciate yall
I hope I can be of help to others too on the platform.
