Rear shock problem
Old May 1, 2002 | 08:41 AM
JonH's Avatar
C230 ~ C5/Auto/CD (on order)
Rear shock problem
Hi all...
Around 3500 miles on my C230K, I noticed a clunking noise from the drivers side rear quarter... I figured it was something with the suspension as it only happened when I hit bumps in the road.
At 5k miles, MB replaced the bad shock... got the car back... great, no problems !!!
Now at about 8500 miles, the noise is back... same place... how could it be that the same corner is killing the shock ???
Has anyone else noticed this problem ???
Thanks,
--Jon
Old May 1, 2002 | 12:19 PM
Mach430's Avatar
Ask if the problem was the shock, or the shock bushing. MB has a habit of needing to replace shock bushings. When they break, nothing keeps the shock from hitting the shock tower, which results in a noise everytime you go over a bump. Usually a broken shock does not make noise.
Old May 1, 2002 | 01:04 PM
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
I think I have that! For about a week now, every time I go over uneven surface I can hear some noise, like rubber rubbing on metal.
What is a shock bushing exactly?
Old May 1, 2002 | 01:24 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
I have that too. Every time I go over a speed bump/hump or enter a driveway it almost sounds like body panels rubbing, or a screwed up bushing. The ride quality is fine, no probs there. I will tell them about it when i take it in for a broken cupholder.
PS My noise is in the front though
Old May 1, 2002 | 01:27 PM
Timmy, my noise is coming from the front too.
Old May 1, 2002 | 04:52 PM
Oofoot's Avatar
2002 c230k
Angry
I have the problem in the front too... took it to the dealer and they tried to fix it with a new brushing they ordered from the manufacturer. It didnt help. So tomorrow they are having me come back and giving me a rental to drive around until they can fix the problem. They've been getting alot of these same problems reported, and this particular dealer has no idea how to fix the problem.
How frustrating.
Old May 1, 2002 | 06:07 PM
How frustrating.
Hi Oofoot,
Please keep me posted on the outcome. Thanks
Old May 2, 2002 | 09:42 AM
JonH's Avatar
hmmm
The workorder for the last fix was shock... but wouldn't they change the bushing at the same time ???
I don't have noise in the front, only when I hit man-hole covers or small pot holes. Other than that the ride is perfect.
Old May 2, 2002 | 12:58 PM
paul-the-limey's Avatar
2001 C240 Elegance Auto Lthr
Hi,
I have a similar problem on my UK spec 2001 C240. The shocks "seem" to be okay as when you go over undulations / big sleeping policemen (road humps) or up and down curbs when parking etc. (ie. it seems to "bounce" okay).
The problem I have is with shallow potholes or raised/lowered manhole covers / drains etc. My car seems to really "crash" and "bang" over these. I took it back to MB and they test drove it over big pot holes and the problem was not apparent. I did try to explain to them the exact symptoms but the dealership was in the sticks and there was a shortage of manholes/drains.
Please let me know the outcome as well. Are anyone elses symptoms like mine?? It is much worse at the back end but is still a bit of a problem at the front as well.
Cheers,
Paul
Old May 2, 2002 | 01:35 PM
Exclamation
Well today I took my car in to have them checked out the noisy front suspension. We testdrove with the shop foreman and it was explained that the noise from rubber rubbing on sway bars.
They applied some silicone lubricant and when I drove away the car sounded a 100 times WORSE, like an old carriage. So, laughing my *** off, I've turned around back to the dealership and called the foreman. Apparently this lubricant needs a few days to work in, until it does it's gonna sound like this.
So I went for a drive out of the city to shorten this process Now with summer tires I had the car hit the speed limiter a few times
Upon return the suspension noises were not much better, I'll give it till monday to wear in.
Old May 2, 2002 | 08:38 PM
o2bsurreal's Avatar
C230 Sport Coupe
Yeah, I have the front end noise too. I can get even get it to happen when my car is parked. If I open the hood, and press on the front of the car (hey, I don't want prints on the hood do I?), then the shocks or something squeak. It just started recently. I don't get why it's just now starting.
Old May 2, 2002 | 09:46 PM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
squeaky front end
I would suspect the anti-roll bar bushings, where the bar is attached to the chassis. A little silicone spray is likely all that's needed.
